CarolOliver's avatar
CarolOliver
Solid Red Light on Hub 3
Hello
As the title suggests, The light at the front has a solid red light instead of the solid white.
This hasn't changed after a reboot and a reset.
Couple of other threads on here indicate that i probably need a new router
Thanks in advance
1 Reply
  • Hi there CarolOliver 👋 Welcome back to our forum and thanks for your post 😊
    We'll certainly be happy to assist with arranging for the Hub to be looked at. Thank you for performing the checks we'd usually advise. I'll send you a PM to confirm your details so we can arrange for an engineer to come and check the Hub.
    Nathan
