Randall_Flagg's avatar
Randall_Flagg
10 months ago
Solid red light on front of router
I have had a constant red light on the front of my virginity router for about 6 months now. I believe this is an overheat light but it’s in a vented area away from direct sulight. What can I do to resolve this?
  • Tudor's avatar
    Please do a pin-hole reset of the Hub3. If the red LED remains after the reset the hub will need replacing. Please report back.
  • Hello Randall_Flagg,
    Welcome to the Community and thanks for taking the time to post here on the forums. I’m sorry to hear of the issues that you’re having with your hub at the moment. I'd be happy to take a further look into this for you however I would need to confirm a few details via private message, please look out for my message and we can get started.
    Kind Regards,
    Steven_L
