teamfloyduk's avatar
teamfloyduk
Superfast
Settings for WiFi pod
I have wifi pod being delivered in the next few days, I've just been looking on the WiFi connect app and saw a setting about merging WiFi networks. Should I actually do this?
I have two different network names one for the 2.4ghz and one for 5ghz
    The Pods will not work unless the Hub is left as “out of the box” settings.  If you need separate SSID’s look elsewhere for your WiFi solution.
  • Vikki_M's avatar
    Vikki_M
    Hi teamfloyduk,
    Thank you for your post and welcome back to our community.
    We would recommend merging the WiFi bands yes, if this isn't done the pods won't connect.
    If you need any further support with this or have any questions at all, please pop back to us and we'd be happy to help.
    • teamfloyduk's avatar
      teamfloyduk
      Superfast
      Hi Vikki_M
      Thanks for your reply, if I do this and want to revert back to separate networks what will be the procedure?
        Turn off the VM Pod and replace it with a decent brand of retail Wi-Fi repeater that supports configuration of split SSID and even different SSIDs for the repeated signal.
        As an example ...
        https://www.toolstation.com/tp-link-wi-fi-range-extender/p52846
        You might what to do this from now as usually folks have split the SSID to get things like IoTs / CCTV / printers to work.
      teamfloyduk
      Superfast
      Mind you yodel still haven't delivered it yet, last tracking update was 7.31 am this morning and still saying it's at their depot. Not looking good
