sb85uk's avatar
sb85uk
4 years ago
Samsung phones not connecting to Hub 5
We have installed the hub 5 and our internet speed is so much better, however my sons both have Samsung phones and they are unable to connect to the hub.
it shows on their wifi lists but then just will not connect. Have tried updating their phones, soft resetting phones, restarting router.
Everything else connects great, except these Samsung devices.
Any ideas?
  • Anonymous's avatar
    Anonymous
    In Review
    Any ideas?
    Yup. The Hub5 is in trial stage with many, many many bugs and issues.
    • jem101's avatar
      jem101
      Superstar
      Gary, no, be fair, it’s on a ‘soft launch’, no; no idea either. 😉
      But, yes, it does have more bugs than the insect section of the Natural History Museum, but look on the bright side, you are providing valuable testing experience for VM and they aren’t even making you pay extra for the privilege. Win / Win, no?
        Anonymous
        In Review
        You can try splitting the Wifi bands and connecting the phones to the (albeit slower) 2.4Ghz band. That seems to work for some people with connection issues.
  • Carley_S's avatar
    Carley_S
    Hi sb85uk
    Are you able to provide the information that Kath_P request? Or have you been able to fix the issue at your end?
    Please let us know if you have been able to fix this and what you have done so that we can advise anyone else having the same issues.
    • amoVM's avatar
      amoVM
      My son is having same issue with 5ghz on Samsung s21 Ultra, it disconnects after a few days and you have to reset the hub to allow it to connect again.
  • I'm having the same issue with my Samsung S22 ultra. I have to reset the Hub 5 every few days in order for my phone to connect, anyone have a solution yet?
    • amoVM's avatar
      amoVM
      Is there any update from the Tech team pls?
      • Adri_G's avatar
        Adri_G
        Hey amoVM, thanks for posting and for the query. Could you please let us know what sort of update you've been expecting from us so I can chase this up for you? Is this regarding the WiFi connection issue with the Samsung device you purchased? Cheers
  • Mike_67's avatar
    Mike_67
    Did you get any resolution on this problem? I’ve just installed a hub 5 and whilst my wife’s older Samsung phone connects to the 5Ghz Wi-Fi my newer A53 will only successfully connect to the 2.4Ghz at usually sub 100Mbps. It also randomly says no internet and resorts to mobile data. We have a relatively small house and I’m probably no more than a 5 metres away from the hub.
    Thankfully everything (as far as I can tell) seems to be working.
    • amoVM's avatar
      amoVM
      No didnt get a fix from VM.
      • Mike_67's avatar
        Mike_67
        Ok thanks.
        I wish I’d have found this thread before upgrading. My Superhub 2 was far from perfect but it wasn’t as dodgy with my phone as the hub 5
