TimTheVanMan's avatar
TimTheVanMan
11 months ago
Repeated internet connection loss and huge numbers of packets lost
For many months now we have had repeated occurances of a total loss of internet conneciton through our hub 3. During these events we still have wifi conneciton to our devices. The hub3 does not show any problems or concerns with the upstream or downstream connections, but simply will not provide any internet connection. On these occasions only a power cycle will correct the issue. I can connect to the hub 3 during the internet connection failure and have tried a soft reboot, but that does not correct the issue. The hub comes back up with no internet connection. Even a factory reset from within the menu does not restore internet. Only a power cycle fixes it.
TV through the Tivo box continues to work through most of these issues.
I havent found any tools to understand what is causing the loss of internet conenction while maintaining good wifi and no issues in the hub3.
The hub 3 is in modem more with a netgear router as wifi performance was poor from the hub3 in the early months we had it (years ago), seemingly requiring regular factpry resets from the pinhole in the back to restore wifi service. I have a home automation that requires some configuraiton to forward some ports. Setting this up in the hub3 is a real pain !
When its working, speed is around 40Mbs, which is nowhere near the average 264Mbs for our M250 package.
A recent quality monitor appears to show a huge number of lost packets I think ?
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/ba0fc960aeaca908cebc5853a7a34abc57b53319-30-11-2024"><img alt="My Broadband Ping - My virgin monitor" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/thumb/ba0fc960aeaca908cebc5853a7a34abc57b53319-30-11-2024.png" /></a>
https://www.thinkbroadband.com/broadband/monitoring/quality/share/e162a056c236e848081894390f34f53f8dc71571
Hub3 info : Downstream
11390000002.535256 qam1
21470000002.434256 qam2
31550000002.435256 qam3
4163000000235256 qam4
51710000001.735256 qam5
61790000001.235256 qam6
71870000001.235256 qam7
81950000001.436256 qam8
92670000000.737256 qam17
10275000000137256 qam18
112830000001.537256 qam19
122910000001.937256 qam20
132990000002.436256 qam21
143070000002.537256 qam22
153150000002.738256 qam23
16323000000338256 qam24
173310000003.238256 qam25
183390000003.538256 qam26
193470000003.538256 qam27
20355000000338256 qam28
21363000000238256 qam29
223710000001.738256 qam30
233790000001.238256 qam31
24387000000138256 qam32
1Locked35.5306000
2Locked34.91078170
3Locked35.7253550
4Locked35.7162480
5Locked35.7114770
6Locked35.5200500
7Locked35.7272780
8Locked36.319240
9Locked37.33060
10Locked37.32030
11Locked37.31330
12Locked37.61470
13Locked36.622415
14Locked37.61710
15Locked38.91720
16Locked38.91660
17Locked38.61240
18Locked38.61340
19Locked38.91380
20Locked38.61130
21Locked38.61050
22Locked38.61400
23Locked38.61340
24Locked38.61270
Hub3 info : Upstream
14960011447.3512016 qam1
23660028246.5512016 qam3
32360007446.5512016 qam5
43010009446.5512016 qam4
54310023146.8512016 qam2
1ATDMA0020
2ATDMA0090
3ATDMA0000
4ATDMA00620
5ATDMA0000
  • The hub is now in router mode, and the Netgear is switched off. I didnt realise that the address would be differnet, so havnt set up a new BQM for the new address yet.
    I can't access the hub from here now, so can't double check the QAM.
  • So with the hub in router mode the BQM looks much better!  https://www.thinkbroadband.com/broadband/monitoring/quality/share/c70ae9988000646ad2b855aa49bbf75ace73935c.
    However, back to the original quesiton : in modem mode, around once a month on average, we have the following-
    * solid wifi connections through the Netgear router, with ability to communicate between devices on the network
    * ability to log in to the hub on 192.168.100.1
    * no issues reported by the hub or network
    * no internet connection for any devices without a power cycle of the hub - no hub menu option will re-enable the connection
  • If anyone could point to software tools or apps that may help to understand what the issue is, I'd appreciate it.
    I'd like to get back to modem mode, and re-enable the router with the rules and port forwarding that is set up there.
