ScriptedPixels's avatar
ScriptedPixels
Remote Reboot
I have the exact same issue. I have to reboot the router by switching it off and on. This is a business router too. There's no pattern to it and the logs don't seem to be clear or persist after a reboot (I'm not sure if there's any way of persisting them?
I'd like to remotely reboot the router too. I have a SIM card dongle attached to the router too and that doesn't kick in when it should either.
It's a CHITA router and I use my own router for the WiFi as the router is really poor (even the engineers recommended I set it to be a proxy to the VM network)
    It not normal to power cycle VM Hubs / Chita Routers.
    Have you checked the power levels and numbers of channels are correct ?
    I'd be paying close attention to the state of health of the Wi-Fi Router
    the failure to failover to SIM / mobile data hints that all is not well.
    Hi ScriptedPixels
    Unfortunately these forums are for residential customers so the help you'll receive will be limited.
    Have yuo spoken to VM Business ?
    There should be a live messenger chat function for VM Business on the following page
    https://www.virginmediabusiness.co.uk/help-and-advice/
    There's also a freephone number 0800 052 0800 or text support on 07480 639 012
    Additionally there's an online Contact Form
    https://www.virginmediabusiness.co.uk/help/s/contactus-form
