koolkat66's avatar
koolkat66
9 months ago
RED SOLID LIGHT on hub
My hub has a red solid light and no connection. The hub was a bit hot to the touch but I switched it off and its no longer hot. I have switched off and on, gave it an hour rest, and trying reset both remotely and with the pin but it just turn solid red immediately. The automated helpline told me to try again in 24h but from what I am reading it may be a fault with the hub, it was definitely hot to the touch and it is also quite old, so would it need replacing?
    If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
  • Thank you. I have done a pinhole reste and it goes straight to red. I'll wait here for someone to get back to me.
    • John_GS's avatar
      John_GS
      Hi koolkat66
      Thanks for posting and welcome back to the community. Thanks also for flagging the red light issue and the tests you've ran. I'll send you a PM now to assist further.
      Best wishes.
