- tansleypayneTuning in
Hello forum team. can you help me with the same problem?
I've tried the chatbot (yuk) and phone/web chat. Support is either non existent or useless.
Mark
I have this same problem. Virgin support is ridiculously poor. I've spent hours over the past few days trying to resolve this. I hope your router is fixed by now.
- Gareth_LForum Team (Retired)
Hello tansleypayne.
Thanks for your first post and welcome to our community.
Sorry to hear you're having an issue with the red light on your Hub
I'd like to investigate this for you and arrange a swap.In the meantime can you make sure the Hub is well ventilated and away from any direct sources of heat.
If you don't mind, I'll need to send you a private message to pass security.
If you can check your logo at the top right of your screen that would be great.
Gareth_L
Related Content
- 3 months ago
- 1 year ago
- 2 years ago
- 2 months ago
