emgarcia99's avatar
emgarcia99
Settling in
Re: Hub 4 2.4ghz wifi connection issues
Hi all
I have the same problem, and even after disabling the Optimizer and setting up the two separate SSIDs, I installed the Wifi Analyser and the HUB is not broadcasting in 2.4GHz, even after restarting and reseting it, any ideas? I'm unable to find an option in My Virgin Media account to report this issue.
  • For faults contact VM Customer Support on 150 or 0345 454 1111 from a non-VM phone.
1 Reply
