Lauramc2024's avatar
Lauramc2024
Re: Boosters not connecting to hub
Hi I’m having exactly the same issue and have been on a call with someone for 25 mins with no resolution. I’m losing a lot of working time and this is very frustrating as it’s obviously an issue with many people. I would appreciate someone fixing it for me. Thanks
1 Reply
  • jbrennand's avatar
    Need more info...
    What..... "exactly the same issues" - are you actually having ?
    What error messages are you getting?
    Does the pod connect  ok when put close the hub?
    Is it a new pod that has never connected ?
    What Hub and Pod models are they
