urgiv's avatar
urgiv
12 months ago
Port forwarding issue HUB 5
Greetings to the esteemed community,
I seek your expertise regarding a technical matter concerning port forwarding on the HUB 5 device. Within my local area network (LAN), I possess multiple "smart devices" that can be accessed and controlled locally through a web browser interface by inputting their respective IP addresses, such as 192.168.0.10, 192.168.0.11, and so on. These devices utilize local port 80 (HTTP) for communication.
However, I am facing a challenge in configuring these devices to be accessible from external locations.
While I have successfully established port forwarding for only one device with the configuration
WAN IP - 86.xxx.xxx.73:190 -> Port forward to -> 192.168.0.10:80,
Subsequent attempts to set up additional rules encounter a conflict within the router due to port 80 being already in use. example WAN IP - 86.xxx.xxx.73:191 -> Port forward to -> 192.168.0.11:80,
I kindly request your assistance in understanding this issue and providing a simplified explanation of the underlying technical concepts. Your expertise in this matter would be greatly appreciated.
Thank you for your attention to this inquiry experts 😉
  • I would never use a windoze pc as router for this.
    Best solution is to use your own WiFi router.   Then either set the hub to modem-mode, or in router mode forward all the external ports you need (190, 192, etc.) directly to your router & do the port translation there.
    Option two would be swap the hub5 for a hub4 which does what you want.
  • hashdef's avatar
    hashdef
    Have today upgraded from Hub 3 to Hub 5 due to failure.  Port forwarding settings that worked on 3 don't work on 5.  It wont let me specify two rules that forward different external ports to port 80 on two different internal devices.
