Baz
1 year agoOn our wavelength
Port Forwarding - Hub 5
I searched for solutions here after a simple port forward to web server didn't work remotely even though locally the server did connect. There are a few threads from people with a problem getting responses from people who don't have a problem but don't offer a solution.
I found that despite having set it up correctly and saved the new settings which stayed set correctly after logout/in again it didn't work. However I have got it to work now.
The solution was to reboot the modem (power cycle). So it seems the save on the setting screen doesn't properly set the parameters.
If you are having trouble try the reboot and report on here if it worked for you too.
