Nigel1971's avatar
Nigel1971
Superfast
6 months ago
Ping, Latency & Packet Loss
Just a question about this really. My minimum latency sits around 18 or 19ms on a ping graph but I’ve seen others connections a lot lower about 10ms or even a bit lower.
Is this based on how far you are from the exchange / cable box on the street or local area connection?
The think broadband monitor graph shows the main min area in green, just interested how it works and how some people show it much lower.
My connection seems fine but this past week seen a lot of dropped packets on my graph but seems to show every other day or so. Can you check if there’s any issue on the line happening?
I’ve done a check and it says my home network has a few problems with a Red triangle next to the broadband bit, all the others are normal in Green.
PS: I use both Ethernet & Wi-Fi
  • legacy1's avatar
    Your ping will not get better on docsis reboot hub will not help
    If BQM is dropping but your connection stays up its a routing issue for BQM.
  • Ping is to Preston, again on the 13th packets lost 2am, 2.30pm and after 10pm. I don’t get it as the connection is staying up.
    The hub 4 test is showing home network issue next to the broadband section, all the rest are fine.
    • Sabrina_B's avatar
      Sabrina_B
      Thanks for the update on this Nigel1971, could you please confirm If you have looked further into the diagnostic problems that have surfaced on your screenshot?
      Let us know.
    The BQM show repeated total service loss events lasting for hours,
    but oddly not a word about that.
    Is 18ms the ping time to Preston or Pasadena or Perth ?
  • There is a lot of packet loss between 3rd & 11th of October too.
    • Vikki_M's avatar
      Vikki_M
      Hi Nigel1971,
      Thanks for your post and welcome back to our community.
      We've had a look at things on our side and the connection looks great 😊
      There doesn't appear to be any issue at all with the service and connection.
      How have things been since posting please?
      Please pop back to us when you can.
  • Here is my graph what was happening between 3rd & 6th October last week.
