gsh68's avatar
gsh68
PC suddenly will not connect to internet either via ethernet or wifi
(When referring to being able to connect to wifi or ethernet I mean connect and use the internet via that method)
Started yesterday afternoon with broadband just going down completely. I tried rebooting the pc, unplugging the hub and hard reset of the hub and nothing worked.
My pc will connect to the internet via a wifi hotspot on my phone or via mifi device no problem, so I know the wifi card is working ok.
Waited ages for CS to answer and while going through the same process with them yet again (running up and down the stairs) the wifi for my smart tv and firestick started working again. However the ethernet and wifi for my pc were still out. My phone also connected to VM wifi no problem. However pc still unable to access internet on either connection.
Finally did yet another hard reset as requested by CS which cut us off (wonderful digital landline) and she did not ring me back. Great customer service. This hard reset knocked out the wifi connection to all devices again.
I rang back and went through the explanation with another CS agent who came back and said he had discovered an intermittent issue and it would be monitored for 24 hrs before deciding if an engineer call out was required.
Doing a service check sometimes got the same message, but most of the time got an "everything is fine" response.
Had to use the personal wifi hotspot for most of the evening but later the firestick wifi started working again.
This morning the pc was also able to connect via wifi but not via ethernet. Wanting to have the wired connection I rebooted the pc hoping this would work, only for it to once again not be able to connect with either ethernet or wifi.
It has remained the same all day.
I got the text this afternoon from VM saying they'd been monitoring and there was no problem found.
Everything remains the same now. My smart tv seems to be running normal speed over wifi as does my phone.
My pc will not provide internet via either wifi or ethernet. My pc connects to any other wifi connections' internet without issue.
I've just tried to connect a Samsung tablet which hasn't been switched on for a few days and the internet is timing out.*
Doing a service check on the VM website just now shows no issues found.
However there is very obviously an issue.
I checked the hub settings (hub 3) and there are no paused devices or anything showing which might be an issue.
*While typing up this message the Samsung tablet suddenly started working on the VM wifi but then 30 seconds later started timing out again.
Does this sound like I need a new hub?
    A Hub fault is always possible.
    A signal fault issue could also give the impression of a Hub fault.
    Take a look in the Hub menu as the stats for the Downstream and Upstream connections.
    Are the power levels / numbers of channels etc with in the expected norms ?
    • gsh68's avatar
      gsh68
      I can't make head nor tail of the upstream/downstream stats - I've no idea what the expected norms are.
      There's a lot of critical/error/warning messages in the network activity log going back to the 23rd
      No ranging response received/DHCP renew warning - field invalid in response/RCS partial service etc
      Is this pertinent?
    Copy and paste the text from the Upstream and Downstream stats into this thread for review.
    • gsh68's avatar
      gsh68
        Channel       Frequency(Hz ) Power (dBmV) Symbol Rate Modulation        Channel ID
      14960000045.5512064 qam1
      23660000045.3512064 qam3
      33010000044.8512064 qam4
      44310000045.3512064 qam2
      52360000044.8512064 qam9
      1ATDMA0030
      2ATDMA0010
      3ATDMA0010
      4ATDMA0040
      5ATDMA0030
      13307500005.540256 qam25
      2218750000338256 qam11
      3226750000338256 qam12
      42347500002.738256 qam13
      52427500003.440256 qam14
      62507500003.440256 qam15
      7258750000440256 qam16
      8266750000440256 qam17
      92747500004.140256 qam18
      102827500004.640256 qam19
      112907500004.840256 qam20
      12298750000540256 qam21
      133067500005.140256 qam22
      143147500005.140256 qam23
      153227500005.440256 qam24
      163387500005.640256 qam26
      173467500005.940256 qam27
      183547500005.540256 qam28
      19362750000540256 qam29
      203707500004.540256 qam30
      213787500004.640256 qam31
      223867500004.640256 qam32
      233947500004.940256 qam34
      244027500004.840256 qam35
      1Locked40.97284
      2Locked38.9134107
      3Locked38.9197153
      4Locked38.9129155
      5Locked40.3103118
      6Locked40.3102127
      7Locked40.360173
      8Locked40.384153
      9Locked40.390188
      10Locked40.3100198
      11Locked40.34493
      12Locked40.37364
      13Locked40.964195
      14Locked40.96181
      15Locked40.98594
      16Locked40.98473
      17Locked40.369191
      18Locked40.97278
      19Locked40.959105
      20Locked40.95160
      21Locked40.37968
      22Locked40.36064
      23Locked40.35762
      24Locked40.95453
    A smattering of errors on the Downstream, but in general the connection stats look fine.
  • I'm borrowing a laptop from my brother in law to test it's ability to connect to both LAN and wifi but can't get it until tomorrow.
    Just to try everything I set up a guest network in the hub and the pc connected without issue. Currently getting 350+Mb/s. Will monitor over the afternoon.
    • Ayisha_B's avatar
      Ayisha_B
      Hi gsh68 👋
      Welcome back to our Community Forums and thanks for your post.
      I am sorry for the ongoing issues wit your service.
      How have things been since your last post?
      Do you still require help?
  • No.
    I called CS again on Friday and got through to the upper level (said they had more power than the regular agents). They noted that my router had not been updated since March and sent updates, had me power off and on but still no joy so they booked an engineer fro Saturday.
    As soon as I explained what was happening to the engineer he said it sounded like the router.
    He replaced it with a Hub 5 and everything has been working fine since then.
    Thanks to those that offered advice.
    • Beth_G's avatar
      Beth_G
      Hi gsh68
      Thanks for your update. Really pleased to hear that the Hub swap resolved the issue.
      If you need any further help, please just give us a shout.
