Nightrise889's avatar
Nightrise889
PC connects to Hub rather than pod that's closer
My computer is connected to the hub rather than the pod, even though the pod is much closer and would result in faster speeds. How do I force my computer to switch to the Pod please? I refuse to believe that in 2025 this is not something that can be done.
  • asim18's avatar
    asim18
    You mentioned you are on a PC.
    Some PC WiFi adapters will have a setting called "Roaming Aggressiveness" in the driver's settings.
    I would try adjusting this setting if your WiFi adapter supports it. It may help or it may not, could be worth a try.
    Right-click Start, select Device Manager.
    Then under Network Adapters double-click your WiFi Adapter.
    Go to the Advanced tab and look for a setting called "Roaming Aggressiveness" or "Roaming Sensitivity".
    This is very easily solved with a retail Wi-Fi Repeater that extends the Wi-Fi on a different SSID.
    VM Pods don't offer this option, so correct placement i.e. mid way between the VM Hub and the computer
    is the only option available to try and bring the VM Pod into use.
    • Nightrise889's avatar
      Nightrise889
      Thanks for your reply. Surely this is a huge flaw in the design of these pods?! My pod is exactly halfway between the hub and my PC - it makes no sense to me that my PC chooses the hub and I can’t configure this.
      • asim18's avatar
        asim18
        Rising star
  • This didn't work for me.  I set the sensitivity to "Highest" on the wifi adapter.  Rebooted laptop but still no joy.  The VM connect app still shows my laptop connected to the hub rather than the wifi pod.  The wifi pod does have multiple other devices connected to it, but not my laptop.  Wondering if anyone knows how to force it to move from hub to pod or vice versa.
    • legacy1's avatar
      welcome to the world of WiFi VM you think it was easy doing it on the hub look how easy it works with a pod!
