NoLndlineTW94DS's avatar
NoLndlineTW94DS
Once again my broadband connection is intermittent. How do I request an engineer visit?
My broadband connection has been intermittent for some weeks. I've check the connections, rebooted and reset the router ...no success. The same thing happened last year, and turned out to be a poor connection at the distribution box in the road.
I've done everything obvious to try to locate the problem, and I have a connection log for the past week showing several outages each day (via the useful Chrome extension internetmon.org).
I've tried contacting Virgin via the chatbot, but that proved to be a waste of time. How do I request an engineer visit?
Thank you.
  • Lets see the data and see if we can spot where the issue lays - do this...
    ______________________
    Post up your Hub/network connection details in the format below and someone will check to see if there is a problem there.  In your browser’s URL type in 192.168.0.1 if in router mode or 192.168.100.1 if in modem mode. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
    Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
  • jbrennand's avatar
    • NoLndlineTW94DS's avatar
      NoLndlineTW94DS
      Thanks John. I fact, I phoned VM and got through to someone surprisingly quickly. They can see there's been intermittency for several weeks. I was offered an engineer visit tomorrow and settled for one on Thursday morning.
      Assuming the problem gets fixed, that's rather better service than I've had in the past!
        Good !  Do set up the BQM as directed above - it will be useful/helpful data to show the Tech.  Note it is a "rolling" monitor so it takes 24 hours to build the first record - so set it up today 👍
