sc29's avatar
sc29
14 hours ago
New Ubuntu Laptop and wifi speed issue
I've just bought a new laptop running linux/ubuntu and experiencing wifi speed issues which I don't have with other devices, including another laptop running ubuntu. The problem I have is that the speed is fine when in the same room as the router but when I go upstairs the speed drops off dramatically. I have 250Mbs broadband and upstairs the speed can be down to 10-20Mbs. Other devices in the same location can get about 80Mbs.
Investigating the wifi signals using LinSSID I've found other wifi signals nearby on channel 11 2.4Ghz so I was wondering whether the issue was due to this. My laptop provider said that the wifi "card" in the laptop is low powered and the the clash of channels could be the issue. So in order to diagnose the problem I decided to change the channel from 11 to 6 on the 2.4Ghz connection.  I have a hub 3 and had to Disable Channel Optimization to do this. However, it seems to have made things worse doing this.
Before I start looking into ubuntu/linux configuration, or returning the laptop, does anybody have any ideas as to what might be causing this laptop to lose its wifi speed, or maybe configure the router better.
Thanks in advance
    If other devices upstairs are returning 80Mb/s download, they are on the 5GHz band.
    You mention the Ubuntu laptop has a low power Wi-Fi adaptor ( that is unusual ) and that its speed was worse with the Hub 3 on 2.4GHz channel 6 than on 11 i.e. the Ubuntu laptop when up stairs is using the slower 2.4GHz band unlike other kit that is on the faster 5GHz band.
    If upstairs is at the fringe of Wi-Fi reception the Ubuntu laptop on 2.4GHz is at a considerable speed disadvantage.
    Consider improving the Wi-Fi coverage in the upstairs of the house so the Ubuntu laptop can revert to the faster 5GHz band.
    • sc29's avatar
      sc29
      Hi Alessandra
      Thanks for your very useful information.
      I don't know if I mislead you slightly as I'm not a wifi expert. The new linux laptop has a Wi-Fi 6E(802.11ax) AX210/AX1675* 2x2 [Typhoon Peak] wifi 6 card which I was told has power saving or lower power.  I have read of issues with that card and low speeds, which is why I'm trying to diagnose where the issue is, especially since no other devices I have have speed issues upstairs.
      If I understand what you were explaining, does a device drop down to 2.4Ghz automatically if the signal is too low for 5Ghz, which makes me wonder why the mac next to it upstairs is still using 5Ghz? It seems to me that the linux laptop can't pick up signals as strongly judging by the fan icon at the top of the screen.
      Anyway, if the new laptop is using the 2.4Ghz band I was trying to change the channel so that it wouldn't conflict with neighbours nearby also on 11.  It did seem to be slower after updating the router, I could be wrong, and I have no wonder why changing the channel from 11 to 6 on the 2.4Ghz would do this. Maybe I didn't update hub 3 properly.
      So in conclusion I don't know whether to update the router to a wifi6 mesh as you suggest, or return the laptop if I'm going to keep getting issues connecting to other networks at different locations.
        Yes fall back from the faster 5GHz band to the slower longer range 2.4 GHz band is automatic and occurs are different points for each Wi-Fi device.
        99% of Wi-Fi issues are due to total failure to invest in a suitable Wi-Fi network for the space you have or the needs / expectations you have.
        We have a VM Hub in Router mode + 2 Wireless Access points, and network sockets in 4 rooms ... we have good Wi-Fi across a home of a dozen rooms on two levels.
        We also have a couple of HP USB3 to Gigabit network adaptors for the modern slim laptops that lack a network port, these give rock solid connections for MS Teams & Telegram video calls & using an Epson network scanner.
