troutiesam's avatar
troutiesam
3 months ago
Network issue - logs provided
Hello everyone,
I’ve been a happy VM customer for around six years. I run the Gig1 service using a Hub 5 (normally in modem mode) with a Deco XE75 mesh system. It has been great for the last 18 months with virtually zero downtime.
On Friday afternoon we temporarily switched off the electrics for some bathroom work. This may be unrelated, but roughly two hours later our broadband went down and has been mostly unusable since. We appear to be the only property on the street affected.
The connection occasionally comes back for a few minutes, but then drops again. For the most part it has been completely unreliable, to the extent that my wife can’t rely on it for work.
I’ve spoken to VM support three times and have an engineer booked for Wednesday. I reset the Hub 5 back into router mode so VM could view the logs. The Hub status consistently reports “Partial Service – DS Only”.
After looking through the Hub logs in detail (with some help from ChatGPT), it appears the problem may require a network engineer, not just a standard home visit. The DOCSIS 3.1 downstream channel seems to be failing to lock, with extremely low PLC power, 0 dB MER, and very high uncorrectable error counts.
Before the engineer arrives, I’d be grateful if anyone could look at the logs (posted below) and advise what the values mean and whether a standard engineer visit is indeed appropriate.
Any guidance would be hugely appreciated.
Thanks very much in advance.
3.0 Downstream Channels (Error Counts)
Channel
Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1 to 32
All Locked
39 to 41
0
0
3.1 Downstream Channels (OFDMA)
Channel Details
Channel
Width (MHz)
FFT Type
Active Subcarriers
Modulation
First Active Subcarrier (Hz)
159
94
4K
1840
QAM4096
1108
Channel Performance
Channel ID
Status
RxMER (dB)
PLC Power (dBmV)
Corrected Errors
Uncorrectable Errors
159
Locked
0
-27.9
4,045,798
1,237,666,709
3.0 Upstream Channels
Power and Modulation
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
0
49600000
42.8
5120
QAM64
1
1
43100000
42.3
5120
QAM64
2
2
36600000
41.3
5120
QAM64
3
3
30100000
41.3
5120
QAM64
4
4
23600000
40.8
5120
QAM64
5
Timeout Summary
Channel
Type
T1
T2
T3
T4
0
ATDMA
0
0
0
0
1
ATDMA
0
0
3
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
3.1 Upstream Channels
Basic Details
Channel
Width (MHz)
Power (dBmV)
FFT Type
Modulation
6
10
37.5
2K
QAM256
Channel Performance
Channel
Type
Active Subcarriers
T3 Timeouts
T4 Timeouts
6
OFDMA
200
74000000
0
0
  • Roger_Gooner's avatar
    Roger_Gooner
    A network engineer doesn't do home visits, and bearing in mind that the problem could easily be the result of excess attenuation in the home or an issue in the cabinet, then a tech is the right person to be called out. Occasionally the drop cable is faulty. It's only if the problem is upstream of the cabinet (possible but unlikely as your DOCSIS 3.0 carriers are perfect) that networking need get involved.
    Don't let the tech go until you've checked the PLC power level again, should be between about −10 dBmV and +10 dBmV and not the high −20s.
  • I tried calling VM again to ask for this to be escalated to the networks team.  I've now got two appointments booked (I think).  The second is a cabinet check.  I guess it might help if I show the engineer who turns up at the house this thread.
    • Steven_L's avatar
      Steven_L
      Hello troutiesam,
      Welcome to the Community, and thanks for taking the time to post here on the forums. I’m sorry to hear of the issues that you’re experiencing with your connection at the moment. Have you had your engineer visits yet?
      Kind Regards,
      Steven_L
      Why not print the problem Downstream stats from the VM Hub,
      evidence on paper is easy to present and so compelling.
      Watch out the the appointment being cancelled if VM discover this
      is a fault related to more than your line.
    -27.9 dBmV   is so low I am quite amazed there is a channel at all.
  • Thanks for your thoughts.  Strange as all neighbours suggesting their VM provided broadband is fine.  Further, there are no faults identified on either the website or via the telephone number you provided. Very strange!
    Here is the issue, the 3.1 Downstream channel power has dropped very low to -27.9 dBmV ( preferred range is about -7 to + 7 dBmV) and the result is many millions of Uncorrectable Errors.
    This is such a severe loss of signal I'd suggest a fault on the VM Network or at a local Street Cabinet.  Given the 3.0 channel stats look ok, I'd expect folks local to you to be suffering the same service issue.
    Check for known faults in your street. Try both methods:
    Call the local fault line: 0800 561 0061 – this is an automated number.
    https://www.virginmedia.com/help/check/status/identification/identify
    As ever with VM Faults, someone has to be the first to report it !
    3.1 Channel Performance
    Channel ID
    Status
    RxMER (dB)
    PLC Power (dBmV)
    Corrected Errors
    159
    Locked
    0
    -27.9
    4,045,798
    1,237,666,709
