MrGiles22's avatar
MrGiles22
Up to speed
My hub has a solid red light.
The other day I noticed that a permanent red light was showing on the Router; the internet is working fine so far, but reading through other comments, seems the red light may be caused by overheating and could be a fire risk. I have already tried switching it off and back on again and red light still shows. So, what can I do for now? Contact Virgin or maybe an advisor on the community pages may help?
  • Engineer turned up the other day, router changed, all working fine, thank you.
  • Zach_R's avatar
    Zach_R
    Hi MrGiles22,
    Thank you for your post and welcome back to our community forums. We're here to help.
    I'm sorry to hear you're having some trouble with your router displaying a constant red light. If you haven't done so already, please follow these steps.
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
    If the issue still remains after following the above then please respond to the private message that I'll be sending to you shortly and we'll proceed from there with this.
    • Ashleigh_C's avatar
      Ashleigh_C
      Thank you for popping back to us MrGiles22 and letting us know and that is so great to hear.
      Please do pop back to the forums in the future should you ever need any further help and we will do all we can to assist.
      Thank you again for your time.
