mahirkhan's avatar
mahirkhan
M500 hub 4 or hub 3
Hi I have ordered M500 and Mixit TV package and I would like to ask if I get the Hub 3, Hub 4 or even Hub 5.
Thank you
Mahir
  • The current Hubs for the M500 tier are as you stated.  You will get either a 3, 4 or 5 depending on stock levels.
  • Hey mahikhan, thank you for reaching out and as mentioned below you will get one of either.
    The Hub5 are for 1GB so most likely it will be 3 or 4.
