sepph's avatar
sepph
Longer coax cable from wall to hub
We switched to Virgin about a year ago. When it was installed the cable used from the wall to the hub was 1m. Is it possible to get a longer cable? I've seen mention of a 3m cable being sent out for free. The cable is of the push on type at both ends.
  • Hi sepph
    Thanks for posting and welcome to the community. I'll send you a PM to help 🙂
    • Iw6's avatar
      Iw6
      Hello @John_GS
      I also would like to get a longer cable sent out. How do I go about requesting this.
      • Carley_S's avatar
        Carley_S
        Hi Iw6
        Welcome to the community forums.
        Are you looking for a rewire or just a longer cable?
        If it's just a longer cable, can you please advise how long cable you're requesting and were in the set up the cable you need is?
