Tankmag84's avatar
Tankmag84
Just joined
4 hours ago
Laptop Connection Issues 5GHZ
Hello,
I have an issue when trying to connect my Dell laptop, Windows 11 business, to my 5GHz network at home.
I currently have my WiFi setup with a 2.4GHz and a 5GHz network. I can connect to the 2.4 without any issues, but when I connect to the 5 I am connected without any internet. The 2.4 is a little slow and this is why i would like to connect to the 5.
Can anyone help with this?
    How are you achieving this?  Are you using the standard Hub with a split SSID, or something else?
    Have you ever paused the Dell laptop at anytime with the Connect app?
    • Tankmag84's avatar
      Tankmag84
      Just joined
      I've done this through the settings on the hub. Some of my smart items, heating monitor, will only operate on 2.4ghz.
      I didn't realise I could pause it on the app. I'll take a look at this.
        You can check this via the Hub's admin console.  Look under the MAC filtering and clear any entries.
