wiggyweir's avatar
wiggyweir
Intermittent large ping spikes - Critical Downstream power level errors on Hub
Hello All,
Looking for some help with a really annoying issue I'm having on my 1Gbps line with Virgin media, speed is fine but intermittently I am getting huge ping spikes that can sometimes reach over 4000ms (see below)
How I noticed this was being on Discord and the connection dropping out intermittently, it can happen once in 5 minutes or many times in quick succession.
I've ruled out the PC by connecting it to a different connection which does not have the ping spikes.
When logging on to the router, I am seeing quite a few errors on the log page:
You will see that I've rebooted the router a few times and reset but the same errors keep coming back up. These errors have been the same since 8AM this morning
11-03-2024 19:49:23noticeGUI Login Status - Login Success from LAN interface
11-03-2024 19:30:33warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-03-2024 19:30:14noticeREGISTRATION COMPLETE - Waiting for Operational status
11-03-2024 19:30:09warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-03-2024 19:30:08warningREG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-03-2024 19:30:08warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-03-2024 19:30:08warningDynamic Range Window violation
11-03-2024 19:30:03noticeDS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-03-2024 19:29:55warningDHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-03-2024 19:29:53noticeHonoring MDD; IP provisioning mode = IPv4
11-03-2024 19:29:38criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-03-2024 19:29:38criticalCable Modem Reboot because of - Reboot Timezone Change
11-03-2024 19:26:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
11-03-2024 19:26:33criticalCable Modem Reboot because of - Reboot Factory reset ACS
11-03-2024 19:26:33criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Would appreciate any help on this as its infuriating me, would these errors be causing the spikes in ping?
Thanks in advance all
    The ping variations shown are on the LAN side of the network.
    What cables / switches etc are between the PC and VM Hub ?
    Do you see the same variations if you ping the Hub from another device ?
