Time | Priority | Description |
15-07-2024 20:58:07 | notice | GUI Login Status - Login Success from LAN interface |
14-07-2024 08:28:25 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
14-07-2024 08:28:25 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
14-07-2024 08:28:21 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
14-07-2024 08:28:16 | warning | Dynamic Range Window violation |
14-07-2024 08:28:16 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
14-07-2024 08:28:15 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
14-07-2024 08:28:15 | warning | Dynamic Range Window violation |
14-07-2024 08:28:15 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
14-07-2024 08:28:10 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
14-07-2024 08:28:09 | notice | TLV-11 - unrecognized OID;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
14-07-2024 08:28:02 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
14-07-2024 08:28:00 | notice | Honoring MDD; IP provisioning mode = IPv4 |
14-07-2024 08:27:36 | critical | No Ranging Response received - T3 time-out;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
14-07-2024 08:27:30 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=##:##:##:##:##:##;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-07-2024 08:27:29 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
13-07-2024 15:42:05 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
13-07-2024 15:36:40 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=##:##:##:##:##:##;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
13-07-2024 15:36:02 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
13-07-2024 15:35:49 | critical | No Ranging Response received - T3 time-out;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
13-07-2024 15:35:49 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
13-07-2024 15:24:48 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=##:##:##:##:##:##;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
13-07-2024 15:24:43 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
13-07-2024 15:24:35 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
13-07-2024 15:24:34 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
13-07-2024 15:24:17 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
13-07-2024 15:24:14 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
13-07-2024 15:23:55 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
13-07-2024 15:23:54 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
13-07-2024 15:23:15 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
13-07-2024 15:23:14 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=##:##:##:##:##:##;CMTS-MAC=##:##:##:##:##:##;CM-QOS=1.1;CM-VER=3.1; |
