Kempy68's avatar
Kempy68
14 days ago
Hub5 not working
Hello,
I had a replacement hub5 delivered on Monday. Spent all day yesterday trying to get it to connect but no internet or very intermittent. Checked all connections are sound - rebooted hub numerous times and makes no difference. Starts off with constant white light, then flashes for a while and then changed to blue flashing light.
I have now reconnected my old hub3 which seems to be working fine. You can have the hub5 back if it’s no good. Let me know what to do.
  • If the older Hub 3 is still working the replacement Hub 5 has not been activated,
    was there a VM phone number to call ( E.g. 0800 953 9500 ) to get the Hub 5 activated ?
  • Thanks for the link and advice.
    It’s a shame VM don’t make this clear when setting up a new hub. Not great for customers. It seems customer support is now non-existent.
  • I’d be happy to keep the hub5 if I can get it activated. Is the 0800 number the correct one to get activated ?
  • Also I have 5 days to activate the hub5 which gives me until Saturday otherwise I will apparently loose the “service”.
    If it’s that much hassle I’d prefer to keep my hub3 ?
    Can someone from VM please enlighten me.
    • legacy1's avatar
      you might as well move to the hub 5 now more Docsis channels and 2.5Gb port
    • Kempy68's avatar
      Kempy68
      No there wasn’t a phone number to activate the hub. No other communication apart from receiving the hub.
