RichardDBlake's avatar
RichardDBlake
Hub not found in Connect app
I am trying to resolve wifi issues using the VM Connect app but it showing ‘Hub not Found’. I have tried rebooting the Hub, deleting the app and reinstalling it after rebooting my phone but no luck.
what can i do to resolve this?
  • Hi Kath_F
    Thanks for replying.
    Firstly, apologies for the dual post. The reason is when I first posted the message I got an error to say there was an error posting, therefore I did it again. Clearly, the first post had gone through, despite the error message.
    Regarding the problem with the connect app. I am connected to my home wifi, I do not have a guest network set up and am not running a VPN. Also, when I first got the error I tried both a normal reboot and a factory reset (holding the reset button for 1 minute) and the issue still remained after both of these.
    Also, I deleted the app from my phone, restarted the phone and then reinstalled the app to ensure that all app data was removed. Again, it did not resolve the issue.
    Regards, Richard
    • Steven_L's avatar
      Steven_L
      Thanks for coming back to us RichardDBlake, I would be happy to take a further look into this for you but first I would need to confirm a few details via private message, please look out for my message and we can get started.
      Kind Regards,
      Steven_L
  • Hi RichardDBlake,
    We're sorry to hear you're having an issue with connecting to your Hub within the Connect App. The first thing to be aware of is you need to be connected to your Home WiFi in order for the app to connect to the Hub. It won't allow the connection if you're on a Guest network, VPN or Mobile data. If this still doesn't help, try clearing the data within the Connect App.
    If you've recently had a new hub then it can also take a few days for the updates to reflect.
    Finally, you can also try a pin hole reset on the hub. Make sure you hold the reset button in for a timed 60 seconds to ensure a full reset is completed.
    Pop back and let us know how it all goes.
    • smitrog's avatar
      smitrog
      Settling in
      I am having the same issue. I have tried everything in forum. I have a Hub 3 and on a Android Google Pixel 7. Please help.
      • Kath_P's avatar
        Kath_P
        Hi smitrog,
        We're sorry to hear you're having an issue with connecting to your Hub within the Connect App. The first thing to be aware of is you need to be connected to your Home WiFi in order for the app to connect to the Hub. It won't allow the connection if you're on a Guest network, have used VPN (or have a VPM installed on the device) or using Mobile data. If this still doesn't help, try clearing the data within the Connect App.
    • T9WPC's avatar
      T9WPC
      I’m having exactly the same problems with all the same remedies to try to fix the issue but VM Connect can’t find the Hub 5. Worked perfectly on my old hub
      • T9WPC's avatar
        T9WPC
        Also my hub has been installed for a few months and all working perfectly
