David81046
8 months agoJoining in
Hub 5 keeps dropping for a few seconds
My Hub 4 keeped dropping and I was upgraded to a Hub 5, this has made the situation worse. I am told that the signal is good up to the house but I have a little noise on the cable in the house. Since the last engineers visit the TV has started to loose signal also. Before I have the cable changed inside the house can someone look at this log from the Hub and tell me if they think that this could be the problem.
| 15-05-2025 07:30:44 | notice | Honoring MDD; IP provisioning mode = IPv4 |
| 15-05-2025 07:30:35 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 15-05-2025 07:30:34 | critical | Cable Modem Reboot because of - HW or Power-On Reset |
| 14-05-2025 23:14:34 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=CMTS-MAC=e;CM-QOS=1.1;CM-VER=3.1; |
| 14-05-2025 23:14:34 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
| 14-05-2025 23:14:34 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
| 14-05-2025 23:14:31 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=;CMTS-MAC=00:01:5c:7b:44:be;CM-QOS=1.1;CM-VER=3.1; |
| 14-05-2025 23:14:31 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=;CMTS-MAC=00:01:5c:7b:44:be;CM-QOS=1.1;CM-VER=3.1; |
| 14-05-2025 23:14:31 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thank you in advance
Mod Edit : Personal details removed
David
