Wadapalava's avatar
Wadapalava
7 months ago
Hub 5 connection. 2 Engineers, 1 Specialist and counting!
So where to start….
I have a 1gig Virgin broadband line (500mbps boosted to 1gbps via VOLT). I have to start by saying that up until my last contract renewal not so many Months ago things were fine, I had next to no problems with my connection at all, very rarely would I encounter a dropout. I would 100% of recommended Virgin to anyone. That isn’t the case now however!
We started getting intermittent drop outs in May this year. The connection would drop for maybe half an hour or so a few times per week. These were frustrating but I put it down to maybe Virgin doing some work their end or something like that.
Bare in mind here I have a son who’s doing his A-Levels and a daughter who is going into her GCSE exam year this year, NOT GOOD.
These dropouts started becoming more frequent and really had me questioning things now. Many times Virgins online status check as being fine in the area, it would take me through the usual power down of hub etc. Sometimes this would work, sometimes it wouldn’t.
I ended up getting an Engineer out. He replaced the metal Coax wall connection. He did various line checks and couldn’t see any issues with that. He assured me it should be fine now, giving me his number in case of ongoing problems.
Needless to say, this fixed nothing. I contacted him and he arranged for a different engineer to visit since he wasn’t available. The next engineer arrived and did the usual checks on the line. Didn’t find a thing. He decided the fault must be with the Hub so changed my older Hub to a version 5. I thought that would definitely sort out the problem… nope.
Dont get me wrong, this did help for a bit. I’m not sure if that was just fluke or what but during the first few days things seemed alright. Then again the dropouts started again.
This time we had complete loss of connection. This didn’t just go on for 30 minutes, we’re talking days of absolutely no broadband. Kids are on summer holidays, they both live on their electronic gizmo’s, Nightmare!
At this point I’m really getting fed up. I’m taking note of the time outs and the duration. I’m taking screenshots of the Log from the Hub itself. These screenshots show critical error messages constantly. Various types. My speed checker showed decent download speeds but none existent upload speeds.
Now onto the SPECIALIST engineer who got booked in for me. What can I say?? The guy couldn’t be bothered to look at any of the evidence I had collected, just kind of shrugged it all off as it was nothing. He mentioned my speed check test being irrelevant since Virgin only use Cisco checks. He replaced the external box saying it actually looked okay but had a bit of corrosion on it. Then he mentioned how many 5g channel connection was one of the high power drain ones so he switched it to one of the lower channels to reduce the power.
He went on to tell me if I needed him to contact him on the number he called me on. I said I hadn’t received a call from him, they had my old number on the system. He stood me it was now updated and he would call me so I had his contact number once he had left. He didn’t do this either.
Roll on to today. We’re still getting constant dropouts, nothing has changed. Looks like possibly another engineer visit and all I can think is what’s the point. Virgin customer service is a complete joke and I’m at my wits end with it all now. I pay a considerable amount for a sub par service and it’s no laughing matter.
Has anyone else experienced anything like this? Is there anything I can do to sort this out.
Please help.
  • I too share your pain.
    Everything was fine until I renewed. We had a Hub3 which was stable but WiFi was non existent, so we paid for a HUb5 upgrade. I get drop outs daily and use the broadband for work purposes as well. I  have complained and they are currently monitoring the line for a week. I don't think it will help as I think the Hub5 is just Sh*t and has loads of problems. I will watch this with thread with keen interest.
    • Nednats's avatar
      Nednats
      Up to speed
      This is likely because the Hub3 uses DOCSIS 3.0 while the Hub5 runs on DOCSIS 3.1. On paper, DOCSIS 3.1 is a big upgrade — it allows more capacity and higher speeds — but it’s also more sensitive to any noise or signal imperfections on the line.
      With DOCSIS 3.0 (Hub3), the connection tends to be more forgiving, so you could have borderline signal levels (e.g. upstream power slightly high, or downstream SNR a bit low) and still not notice many issues. With DOCSIS 3.1 (Hub5), those same borderline levels can cause daily drop-outs, packet loss, or latency spikes.
      Virgin’s monitoring may just say “no fault found” if the connection doesn’t fully drop while they’re watching, but the real problem is often in the power levels and SNR (signal-to-noise ratio). If you log into the Hub’s status page, check that your downstream power is ideally between -6 dBmV and +6 dBmV, upstream power between ~34–50 dBmV, and that SNR is above 35 dB. Anything outside those ranges can cause what you’re seeing.
      If the WiFi is the main problem, putting the Hub5 in modem mode and using your own router usually gives far better stability.
      If you are watching this thread you might also want to follow my on-going issues:
      Hub 5 stuck on DOCSIS 3.0 – Ranging Failures, High Upstream Power, DOCSIS 3.1 Not Engaging | Virgin Media Community - 5652510
      Ongoing Complaint Handling Issues – Data Protection & Support Failures | Virgin Media Community - 5664032
