Mich1's avatar
Mich1
Hub 5 and Alexa
Hi there Jim. I have exactly the same problem as you posted, but I don't understand any of the answers! I am 70 years old and NOT tech savvy. I just want to connect my Alexa's, which I use all the time, but I need simple instructions! Please can you help?
Regards from Michele.
  • jbrennand's avatar
    What exactly do you mean by "my  Alexa's"?
    Alexa is a voice activated application for connecting devices to the Hub - so what are the individual devices (make & model) that you want to connect ?
  • JamesB1's avatar
    JamesB1
    Hi, I think, you should be able to connect using the Alexa app which you should have, or can get, on your mobile phone.
    Regards, Jim.
  • Hey Mich1, thank you for reaching out and a warm welcome to the community.
    To connect an Alexa with a  WIFI connection please follow these steps;
    1. In the Alexa app, open the left panel menu and then select Settings.
    2. Select Device Settings.
    3. Choose your device.
    4. Select Change next to WiFi Network and follow the prompts in the app. Cheers
