gwynnej3's avatar
gwynnej3
4 months ago
Hub 5 (6months old or so) 2.4gHz WiFi stops
My recent (2025) Hub works fine for lengthy periods, then the 2.4gHz wifi stops. Power-cycle the hub and it works normally again.
I've seen other users on here with the identical issue, so I know I'm not the only one :-)
Virgin Media can you advise please.
Cheers - John
  • gwynnej3's avatar
    gwynnej3
    PS - the interval between these events is typically weeks - long enough I don't make a note of the time.  I could live with it except it stops most IOT devices working.
    Thanks again
    • Molly_T's avatar
      Molly_T
      Hi Gwynnej3 👋 Welcome to the community forum! Thanks for posting.
      Sorry to hear these concerns about your hub and the Wi-Fi.
      Can you try doing a pinhole reset on your hub, and let us know if it continues to have the same issue?
      We can usually check data on your hub from the last month, but if the issue is happening less regularly than that - it may be worth keeping a little tracker of the data so we can take a closer look when offering additional support.
      Let us know how you get on! 🤞 Thanks for your patience in the meantime. 🌞
      • gwynnej3's avatar
        gwynnej3
        Thanks, I’ll try that and let you know how I get on.
  • legacy1's avatar
    VM may send you a new hub but really its not going to fix best to look at getting your own router with 1Gb o 2.5Gb ports and put hub in modem mode.
  • HughJarsse's avatar
    HughJarsse
    Knows their stuff
    Had this for around 3 months now, (see my original post here) 2.4g wifi keeps dropping off | Virgin Media Community - 5679111
    VM are aware of the problem apparently, and yet 3 months on, still don't have any idea what it is, or how to resolve it, apart from 'resetting the hub' when it happens.
    Read the replies from VM staff on here in the post mentioned, shows just how little they are interested in fixing problems, while they've got your custom, and your monthly money safely in their bank account.
    My contract is up next month, so looking to get away from this bunch of 'couldn't care less' cheapskates. There are better deals out there.
  • Dispite what the mods may say - VM are aware of this issue and we await a fix.
    I wonder if VM still do beta testing??
    • jpeg1's avatar
      jpeg1
      Yes @ozsat, they have a large group of beta testers. They are called customers.
      • legacy1's avatar
        And the only customers they need to care about are the ones using modem mode because if VM can't do that right we might as well nuke are self's.
  • Wow, that has been happening to me.
    Glad to know I am not alone.
    However I just swap networks, stay on that for a while, and then back again and it is working again.
  • Roger_Gooner's avatar
    Roger_Gooner
    All the symptoms reported by the OP point to a power problem caused by a failing external PSU or internal voltage regulator. No amount of reseting will help. VM should send a replacement hub and power adapter.
    It also reads like Hub 5 on flaky Software version : LG-RDK_11.6.2-2410.1 (from Sept 2025)
    where Wi-Fi and DHCP repeatedly fail requiring a reboot or reset.
    Login to the Hub 5 admin menu,   look at the DHCP page,
    do you see devices that are not working listed with a Lease time of Zero ?
  • Simple solution is to use a separate router connected by cat 8 patch lead, does not look pretty but very effective with excellent range. I got a used one for £33 that i use for CCTV cameras on 2.4GHz.
    Tenda AC23 AC2100 Smart WiFi Router - Dual Band Gigabit Wireless
    https://www.amazon.co.uk/dp/B08P741QWS?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
    • gwynnej3's avatar
      gwynnej3
      I got one of these - £20 off eBay - just set it up today. See how we get on!
