yamaxt's avatar
yamaxt
9 months ago
Hub 3 solid red light
I have a hub 3 with solid red light and tried several times with reset etc. It use to be white or green this has gone on for approximately 4 months now and box is very warm is there a issue with this. My wifi drops alot aswell
  • Tudor's avatar
    Please do a pin-hole reset and if the red LED persists then the hub will need replacing.
    • yamaxt's avatar
      yamaxt
      Hi thank you for your response unfortunately I have tried this on many occasions but not resolved the issue. So not sure what to do next 😕
      • Tudor's avatar
        Someone from VM will be in contact.
