KK-84's avatar
KK-84
3 days ago
How to order VM Pods?
Hello,
I'm a Volt 250 customer. I have black spots in my house and areas where the speed significantly drops. I used the VM Connect app and got speeds of less than 30mbps, but I end up cycling back with no option to order a pod. It's getting beyond frustrating. Can anyone from VM help?
  • Hi KK-84 👋 Welcome to the community forum! Thanks for posting.
    Sorry to hear you are having some difficulties ordering Wi-Fi POD's via the Connect App 👉 https://virg.in/connectapp after running some testing.
    I will send you a PM to offer further support. If you can please keep an eye on your Inbox 📩 in the top right corner of the page. We can then return to this public thread with another update when possible.
    Thanks for your patience in the meantime! 🌞
  • Unfortunately I’ve had the same issue since October 2023. VM customer service and their website/apps are useless. If there was another full fibre provider available to me I would leave but I’m stuck with them. I’m looking at getting a better router and putting my 5x into modem mode to improve coverage
      Modem mode on the Hub 5X does not work yet …
