forshawj's avatar
forshawj
Up to speed
How to get Wi-Fi Pods reset?
I just upgraded Hub to V5 and thought I would give the Wi-Fi Pods another try .. as I had read that they perform much better compared to the V4 which never was reliable for me...
I plugged in one of the Pods and used the Connect utility but this doesn't see the pods. I guess that the pods need resetting as they previously were configured for the V4.
So I rang VM support and asked about getting 3 pods restarted... Well I got to the first one YAAJ1350**** and doesn't appear on VM's support system 😞 So I rang off...
Any idea HOW I can get the pods reset? Is there a simple process? Ringing 150 doesn't seem to be the answer 😞 Or do I need 3 NEW pods and can send the olds one back... ?!
Jeff
  • Hi. I’m in the same boat. My pod is not connecting to my broadband.
  • Hi, I have the same problem. Hub 5 installed after Hub 4 failed. But my 2 pods have not reset.
    You seem to need help from a Virgin moderator. If so I would be grateful if you could reply and advise
      Hi derryvolgie,
      The pods need pairing with the hub 5.   Call the equipment activation number on 0800 953 9500. You will need the model numbers, serial numbers/MAC addresses off the barcode stickers of all pieces of kit and also your account number.
      • derryvolgie's avatar
        derryvolgie
        Hanging out
        Thanks I will gather that information and make the call.
      Hi derryvolgie,
  • Hi  - I also have this issue. Been on help call (got cut off) and help chat - neither seemed to suggest the pods need resetting in some way. Eventually told they are faulty but that cannot be right as I have three and all worked with the hub 4 this morning and now none connect to hub 5. Got cut off again so not sure if they are sending a new one. I sent them this link as well and still didn't comment! Someone who has had this fixed please do let me know what the solution was
  • Hello everyone, I have exactly the same problem - I installed a new Hub 5x, and the pods that I got from a friend refuse to cooperate, they only flash white / the second blue green very slowly. Can anyone help me please?
    • Sephiroth's avatar
      Sephiroth
      Good luck with that, mate.  The pods you got from a friend are VM's property (like the Hub) and they do not like the passing on of their stuff.  They'll want you to order pods directly from them and they they will be activated.
      Do let us know if VM allows you to keep the pods you got from a friend.
      • Arekzx9r's avatar
        Arekzx9r
        Thank you Sephiroth for your answer. So I understand that the pods I have are useless to me?
        I have had the 5x Hub with the M350 plan for three weeks and everything is fine, I only have a problem with the cameras outside. I spoke to the engineer after the installation and he said that VM is only interested in the signal inside the building.
  • I have the same problem need a pod resetting so I can add it to my network if anyone could help It would be much appreciated thanks
    • Daniel_Et's avatar
      Daniel_Et
      Hi Markh77, thank you for your post.
      We're sorry to hear about the problem you're having 😔
      In order to look into this for you, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
      Regards,
      Daniel
      • Palmer10's avatar
        Palmer10
        Settling in
        Hi I’m having the same trouble setting up a booster for the first time
        cheers
  • Same issue here - hub 5 replaced due to being borked by software update but neither pod is shown as connected via the app. Would appreciate any support. Thanks
    • Alex_RM's avatar
      Alex_RM
      Hi LordNozzle,
      Thanks for posting and welcome to our community 😊
      Sorry to hear you're having some issues with the Pods since your hub was changed.
      So I can help, I've popped you over a private message to get a few more details from you.
      Alex_Rm
  • Many thanks for the help, Sabrina B. The problem is now solved.
    • Zach_R's avatar
      Zach_R
      Hi Bob32
      Thank you for the update on this. I'm glad to hear that this has now been resolved for you.
      Please do let us know if there's anything more that we can help you with.
  • Hi forshawj,
    Thanks so much for sticking with me via private message on this one.
    I'm really glad things are resolved now and the pods are working better than previously.
    If you have any further issues then feel free to pop back to us in the Community and we can help you further.
    Many thanks,
    • lukehiggins10's avatar
      lukehiggins10
      Hi, I have the same issue. New Hub 5 installed which is working great but can get the wifi pods to work.
  • Hi forshawj,
    Thanks for sticking with me via private message.
    I'm glad we've been able to help and there is a plan for moving forward.
    I look forward to hearing back from you in a few days when your new pod arrives.
  • Hi Jeff,
    Thanks for your post and apologies to hear your WiFi Pods weren't reconfigured for you when the hub was updated.
    This will need to be done they will connect to the new hub. We'll need to check a few details with you to allow us to check things further for you so I have sent you a direct message to allow us to do this with you in a private space. Just click on the little envelope at the top right-hand side of the page to access your inbox.
    • elle__tay's avatar
      elle__tay
      I'm having the same issue. Hub 5 installed today and now my WiFi pod is just blinking white and no pods detected in the connect app.
      I knew I'd have this problem and made a point of asking the engineer about the pod and he assured me it would be working within 15 minutes of being turned off and on again. I've tried cabling it into the router and moving it closer.
      My pc doesn't have WiFi so this pod is the only way my pc will work and now I'm left without when I have work to do!
      Someone please help me to get this up and running asap as I can't do anything without it!
      • Reece_MH's avatar
        Reece_MH
        Hi elle__tay 👋
        Thanks for your post, and a warm welcome back to the Community Forums.
        I'm sorry to hear you're experiencing issues with your Pods after a Hub replacement. In usual cases, the Pods do automatically pair to a new Hub, but can sometimes fail. I'm going to send you a private message, so we can look into this.
        Please look out for my message in the top-right, white envelope or by tapping your profile picture and then "Messages".
