asim18
2 months agoRising star
If your tesla is having trouble assigning IP address using auto-DHCP, you can try setting a static ip for the tesla.
Give the tesla a manual IP address outside the automatic DHCP range (to avoid any IP conflicts).
You can find the current DHCP range in your tenda web config page.
James19790
2 months agoTuning in
That’s a great suggestion - thanks. Not 100% sure how to do that but will have a google and will give it a go. I know the Tesla WiFi isn’t dodgy as it’ll connect to my phone as a hotspot and as fine before the change to the Tenda. I’ll try the static IP idea 👍🏻
Related Content
- 3 months ago
- 4 months ago
- 3 months ago
- 11 months ago
