- Client62Alessandro Volta
To save some time, tell us how exactly how each device connects
and list exactly what you have tried for each device
and what error messages occur. - jbrennandVery Insightful Person
I am guessing that device is only connecting on the 2.4 GHz band (is that correct?) and if so it may be struggling to connect with the combined SSID - so try this and see if it works.
Log into the Hub settings navigate to the wireless page and tick the "disable" 5GHz box. Save settings and exit and then try to connect the device again - to the remaining 2.4 signal. Then go back in and switch the 5GHz signal back on and save/exit.
See if that sorts it first
- legacy1Alessandro Volta
get yourself a better wifi router with 1Gb ports or better and double NAT to the hub and wait for modem mode
Related Content
- 4 months ago
- 3 months ago
- 1 year ago
