jenkelly's avatar
jenkelly
Having Issues with my WiFi connection
Hi, did you manage to get a hub 5?
I also have 1 gig broadband and have hub 4, the bed room is about 7 meters away from the hub and I can’t get a signal.
I live in a new build flat so not thick walls, surly I should be getting a signal being not that far from the hub?
how do I go about getting the new hub 5?
apparently the signal is much better?
either that or I will just cancel and head over to sky.
  • jbrennand's avatar
    Its not just about wall thickness.  E.g....If they are made of Victorian red bricks - then these are very "iron rich" and make a good Faraday cage to attenuate wifi signals - as do modern thin plasterboard walls lined with aluminium backed insulation !
    If those (or something else) is affecting your signal, then a Hub5 wont help.  You need to improve the wifi signal in the property.
    Do you qualify for free VM "Wifi Pods" - if so - get one and try it first.
  • Hi jenkelly
    Welcome back to the Community Forums.
    I'm sorry to hear you're having some issues with your WiFi connection.
    Whilst your WiFi connection from our end looks OK, I can see that your downstream power levels are out of spec, which will be causing connectivity and speed issues. I'll need to book in a home engineer visit for you so this issue can be fixed 😊
    I've sent you a private message so I can arrange this with you.
