Toonarmy1973's avatar
Toonarmy1973
Fibre cable for hub 5
Does anyone know where I can get a fibre connection cable from fast, will take upto 5 days from virgin which means no Internet for 5 days
It's the cable from the wall to the hub with 2 green ends on... I snapped it moving
    There are fibre cables on Amazon if you can spot once with the correct fitting.
      • Matthew_ML's avatar
        Matthew_ML
        Hey Toonarmy1973, thank you for reaching out and a warm welcome to the community I am sorry to hear your cable has snapped.
        Let me send you a DM.
  • The cable is like this both ends
     this is the cable I need   virgin sent me the complete wrong cable . I informed them the cable with 2 green ends this is the cable they sent
    The OP has posted images of a CATV / Coax cable and a Fibre optic cable.
    Which Virgin Media configuration contains both types of cable ?
        We have RFoG - there are no fibre fly leads,
        The fibre cable goes direct to the ONT in one 150 meter run from the street cabinet.
  • The link in the second post gets you the correct cable next day delivery.
    Or, you can continue the "Virgin wheel of misfortune" for a few more weeks.
