sumner1185's avatar
sumner1185
Just joined
4 months ago
Extend wifi to garden room
Hi, I would like to understand if I can book an engineer to come out and extend my wifi out to my garden room. From the location of the router the distance is probably 100 feet or more. Any help or advice would be great. Thanks.
  • jbrennand's avatar
    They cant/wont simply extend your internet connection into a garden room - you can easily do it though.
    Run exterior grade Cat6a ethernet cable from the hub to the outside garden room and then attach an extender on the other end of it.  Good ones start at ~£40.
    There are other solutions - but this one is the best.
