mda99das
1 year agoUp to speed
Ethernet taking a while to get DHCP and connectivity
I have a win 11 PC and have noticed that with the wired ethernet connection via a netgear switch and sometimes connected directly to the Hub 5 when I turn the PC on and launch chrome it can take a couple of mins for it to spring into action.
As a quick fix, if I physically remove the ethernet cable from the netgear switch and plug it back in, then within 5 seconds all is normal.
what gives?
