nohoho's avatar
nohoho
Ethernet cable help
I’m looking to use an Ethernet cable for online gaming, is it as simple as sticking one end into the hub5 and the other into console?
Or, would I need to change any settings on the hub for my console to pick up the internet?
Is there a specific type of Ethernet cable that is best suited for the ps5?
  • jpeg1's avatar
    jpeg1
    Get a Cat 6 cable. Any higher number is a waste of money.
  • Hey nohoho, thank you for reaching out and to answer your questions as jpeg1 I would advise a CAT 6 also.
    Especially if the console is a new gen type, any other answers do let us know :)
    Enjoy the rest of your day.
