lozzaloz90's avatar
lozzaloz90
Echo dot won't connect to wifi
We have recently moved from sky to virgin and everything is great except 1 of our echo dots refuses to coeect to the WiFi. We have 3 others which are all fine but 1 is not.
I've tried resetting it, turning the WiFi off, moving rooms and tried to use my phone to hot-spot it but nothing is working.
The alexa app can find the dot but when I put the details in for the WiFi it won't connect can anyone help?
  • Lee_R's avatar
    Lee_R
    Hi lozzaloz90 thanks for posting and welcome to our community.
    Sorry to hear you're unable to connect your 4th Echo dot to our hub. Were all 4 previously working on your former provider? When you say hotspot, do you mean just that? To essentially attempt to connect the dot you mobile data connection?
    Lee_R
    • lozzaloz90's avatar
      lozzaloz90
      Yes everything worked while we were with sky, I had a look online and it mentioned hotspotting it through my phone as a possible work around but that didn't work either so I ran out of things to try
      • Matthew_ML's avatar
        Matthew_ML
        Hey lozzalot90, thank you for reaching out and I am sorry to hear this isn't working.
        Can I just confirm is it trying to connect to the 2/4GHZ?
