CM16's avatar
CM16
Constant problems after moving to Hub 4
After existing Hub 2ac was replaced with a Hub 4, we are having random restarts of the router of several times per day. The Hub 4 is used in modem mode, as was the Hub 2ac, we had no issues with the Hub 2ac, it worked 24x7 without issues.
Log file of the router below, with MAC addresses redacted.
Fri 07/03/2025 07:43:56 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:22 3 No Ranging Response received - T3 time-out;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Thu 06/03/2025 10:43:37 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Thu 06/03/2025 10:14:42 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Wed 05/03/2025 20:48:35 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Wed 05/03/2025 20:31:29 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Wed 05/03/2025 20:31:19 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Wed 05/03/2025 20:31:04 6 CM-STATUS message sent. Event Type Code: 2; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Wed 05/03/2025 13:54:08 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:19 3 No Ranging Response received - T3 time-out;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Tue 04/03/2025 20:18:32 6 US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Tue 04/03/2025 18:41:04 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Tue 04/03/2025 18:29:58 6 US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Tue 04/03/2025 17:47:38 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Tue 04/03/2025 17:41:04 4 DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Tue 04/03/2025 17:30:51 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Tue 04/03/2025 17:26:53 6 CM-STATUS message sent. Event Type Code: 5; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Tue 04/03/2025 17:26:21 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Tue 04/03/2025 17:21:01 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:20 3 No Ranging Response received - T3 time-out;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Tue 04/03/2025 17:18:26 6 SW download Successful - Via Config file
Tue 04/03/2025 17:16:46 6 SW Download INIT - Via Config file cmreg-vmdg640-bbt060-b.cm
Tue 04/03/2025 17:16:30 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
Tue 04/03/2025 17:11:16 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=RedactedMacAddress;CMTS-MAC=RedactedMacAddress;CM-QOS=1.1;CM-VER=3.1;
  • CM16's avatar
    CM16
    Thanks newapollo, taken advice and posted other info before asked:
    3.0 Downstream channels
    2 147000000 14.3 39 QAM256 2
    1 139000000 14.5 39 QAM256 1
    3 155000000 14.2 40.4 QAM256 3
    4 163000000 14.1 39 QAM256 4
    5 171000000 14.8 40.4 QAM256 5
    6 179000000 15.3 40.4 QAM256 6
    7 187000000 15.4 40.4 QAM256 7
    8 195000000 15.5 40.4 QAM256 8
    9 203000000 15.6 39 QAM256 9
    10 211000000 15.7 40.4 QAM256 10
    11 219000000 15.7 38.6 QAM256 11
    12 227000000 15.6 40.4 QAM256 12
    13 235000000 15.8 40.4 QAM256 13
    14 243000000 15.7 40.4 QAM256 14
    15 251000000 15.6 40.4 QAM256 15
    16 259000000 15.7 40.9 QAM256 16
    17 267000000 15.7 40.4 QAM256 17
    18 275000000 16.2 40.4 QAM256 18
    19 283000000 16 40.4 QAM256 19
    20 291000000 16 40.4 QAM256 20
    21 299000000 15.9 40.4 QAM256 21
    22 307000000 15.8 40.9 QAM256 22
    23 315000000 16.2 40.4 QAM256 23
    24 323000000 16.4 39 QAM256 24
    25 331000000 16.4 40.4 QAM256 25
    26 339000000 16.4 40.9 QAM256 26
    27 347000000 16.1 40.4 QAM256 27
    28 355000000 15.9 40.4 QAM256 28
    29 363000000 15.9 39 QAM256 29
    30 371000000 15.9 40.4 QAM256 30
    31 379000000 15.8 40.4 QAM256 31
    2 Locked 38.983261 0 0
    1 Locked 38.983261 0 0
    3 Locked 40.366287 0 0
    4 Locked 38.983261 0 0
    5 Locked 40.366287 0 0
    6 Locked 40.366287 0 0
    7 Locked 40.366287 0 0
    8 Locked 40.366287 0 0
    9 Locked 38.983261 0 0
    10 Locked 40.366287 0 0
    11 Locked 38.605377 0 0
    12 Locked 40.366287 0 0
    13 Locked 40.366287 0 0
    14 Locked 40.366287 0 0
    15 Locked 40.366287 0 0
    16 Locked 40.946209 0 0
    17 Locked 40.366287 0 0
    18 Locked 40.366287 0 0
    19 Locked 40.366287 0 0
    20 Locked 40.366287 0 0
    21 Locked 40.366287 0 0
    22 Locked 40.946209 0 0
    23 Locked 40.366287 0 0
    24 Locked 38.983261 0 0
    25 Locked 40.366287 0 0
    26 Locked 40.946209 0 0
    27 Locked 40.366287 0 0
    28 Locked 40.366287 0 0
    29 Locked 38.983261 0 0
    30 Locked 40.366287 0 0
    31 Locked 40.366287 0 0
    3.1 Downstream channels
    33 96 4K 1840 QAM4096 424
    33 Locked 42 16.3 63758444 0
    3.0 Upstream channels
    1 36600000 40.3 5120 KSym/sec QAM64 3
    2 23600000 39.5 5120 KSym/sec QAM64 5
    3 30100000 39.8 5120 KSym/sec QAM64 4
    4 43100000 40.8 5120 KSym/sec QAM64 2
    5 49600000 41 5120 KSym/sec QAM64 1
    1 ATDMA 0 0 0 0
    2 ATDMA 0 0 0 0
    3 ATDMA 0 0 0 0
    4 ATDMA 0 0 0 0
    5 ATDMA 0 0 0 0
    3.1 Upstream channels
    6 10.4 44.6 2K QAM128
    6 OFDMA 208 53.4 0 0
    General Configuration
    Network access
    true
    Maximum Number of CPEs
    1
    Baseline Privacy
    true
    DOCSIS Mode
    3.1
    Config file
    SFID
    52380
    Max Traffic Rate
    287500061
    Max Traffic Burst
    42600
    Min Traffic Rate
    0
    Primary Upstream Service Flow
    SFID
    52379
    Max Traffic Rate
    27500061
    Max Traffic Burst
    42600
    Min Traffic Rate
    0
    Max Concatenated Burst
    42600
    Scheduling Type
    bestEffort
    • Daniel_Et's avatar
      Daniel_Et
      Hi CM16 👋 Thank you for your post and welcome to the Virgin Media Community 😀
      We're sorry to hear about the problems you've been having 😔
      Have you tried following all the advice provided by Tudor? If so, are you any further forward with this?
      Regards,
      Daniel
      • CM16's avatar
        CM16
        Hi Daniel,
        spoken to support on 150 this evening, faults found on hub, replacement hub being sent. Will try this to see if issue is fixed.
  • Tudor's avatar
    Power levels are way too high.
    Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
    VM will not dispatch any technicians while an area fault exists.
    If no area faults found:
    The primary place to report faults or for service requests is Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
    All the downstream power levels vastly exceed the preferred range of  -7 to + 7 dBmV.
    When the Hub 4 was installed was an attenuator removed from the coax cable ?
    If not, an engineer visit is required to correct the downstream power levels,
    across all channels to ...
    • CM16's avatar
      CM16
      No, I installed the hub; removed old 2ac and replaced with Hub4, same cable etc. nothing changed but hub.
      Reported to Virgin via 150, they ran tests concluded it’s a hub fault and are sending replacement. I did mention the downstream power levels to them and I’d gathered the info. I suspect another call will be occurring when this replacement hub has issues.
      • Kath_P's avatar
        Kath_P
        Hi CM16,
        Thanks for coming back to us to update us. We're happy to hear that the team were able to get things moving for you.
        Once the new hub is installed, please monitor things and let us know if the issues continue. If they do, we'll be on hand to help further.
        Many thanks,
  • The Upstream levels are actually good, so what you need is a "forward path attenuator" to bring the downstream lower by 6-10db.
    Do NOT let them use a generic wideband attenuator, because that will mess up your upstream levels & cause more issues.
