Speller's avatar
Speller
11 months ago
Connection problems now hub rebooting
https://www.thinkbroadband.com/broadband/monitoring/quality/share/570576fba285e8befb3df6b2d62cf8ec4d48b676
12990000003.236256 qam21
21390000001.226256 qam0
31470000000.725256 qam0
4163000000-0.726256 qam4
5171000000-0.530256 qam5
6179000000-1.528256 qam6
7187000000-0.729256 qam7
8195000000-0.530256 qam8
9203000000-0.229256 qam9
102110000000.929256 qam10
112190000001.429256 qam11
12235000000135256 qam13
132430000002.235256 qam14
14251000000337256 qam15
152590000002.437256 qam16
162670000001.738256 qam17
172750000001.236256 qam18
18283000000336256 qam19
192910000003.537256 qam20
203070000002.533256 qam22
213150000002.234256 qam23
223230000003.737256 qam24
1Locked36.84710
2Locked2669350029273094
3Locked25.177929966736
4Locked26.71064650219318136
5Locked30.5685573577
6Locked28.723275088809236
7Locked29.9244896574756
8Locked30.623848991939
9Locked29.825471914464
10Locked29.52645048574
11Locked29.424649768225
12Locked35.5418360
13Locked35.2131990
14Locked37.36460
15Locked37.63070
16Locked38.94050
17Locked36.626560
18Locked36.66210
19Locked37.32760
20Locked33.9173253401701058
21Locked34.216917478805791
22Locked37.61730
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
14309999651512064 qam2
22359998651512064 qam5
33010001451512064 qam4
43659997151512064 qam3
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
3ATDMA0000
4ATDMA0000
TimePriorityDescription
18/05/2025 14:35:26Warning!Lost MDD Timeout;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:34:4Warning!RCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:33:30Warning!Lost MDD Timeout;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:33:18Warning!RCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:33:18Warning!Lost MDD Timeout;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:33:10Warning!RCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:33:0ErrorService Add Response rejected - Invalid transaction ID;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:32:55ErrorService Add Ack rejected - Invalid transaction ID;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:31:26Warning!Lost MDD Timeout;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:31:20Warning!RCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:28:40criticalNo Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:28:39Warning!Lost MDD Timeout;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:28:33Warning!RCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:25:2Warning!Lost MDD Timeout;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:23:52Warning!RCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:22:19Warning!Lost MDD Timeout;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:22:14ErrorService Add Response rejected - Invalid transaction ID;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:21:58Warning!Lost MDD Timeout;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:20:19Warning!RCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
18/05/2025 14:19:43Warning!Lost MDD Timeout;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
Continually losing connection and now the hub has stared rebooting itself
  • Tudor's avatar
    Unless there is an area fault you need a technician’s visit to rectify. Your power level are too low and downstream and too high on upstream. Check all connections are tight.
    The primary place to report faults or for service requests is Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post
  • I've been looking at service status, most of the time it says no problems.  A couple of times it has said intermittent signal then goes back to no problems.
    The red LED is on but it has been for a long time I see they can fail, it was orange after a reset in router mode then back to red in modem mode.
    I was hoping to get help here to avoid a phone call.
