Duke25's avatar
Duke25
Connection issue
It appears that l have WiFi connection issue, it won’t able to connect effectively since 8PM. Been tried to switch the router off twice. Is that something to do with the weather? Been tried to look at the troubleshooting or virgin broadband report, still no luck!
  • Ashleigh_C's avatar
    Ashleigh_C
    Hi there Duke25
    Thank you so much for your post and welcome to the community forums, it's so great to have you here.
    I have taken a look on my side and I can see some issues that would require an engineer to take a closer look. I will pop you a private message so we can get one arranged.
  • Tudor's avatar
    You should really refer to it as your "broadband connection" not WiFi.
    Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
    VM will not dispatch any technicians while an area fault exists.
    If no area faults found:
