pwater1's avatar
pwater1
Connection Drops - Hub 5
Hi All
I have had VM for a while but have recently changed to using it as my main connection. I had my hub4 swapped for a 5 and since I have set it all live I have been seeing connection drops at least a few times a week, usually few times a day. It only drops for maybe 1m, but is enough to cause an issue.
I had an engineer out who said everything was fine, but my bqm shows the drops, doesn’t seem to matter if I have the hub in router or modem mode. The drops coincide with:
Started Unicast Maintenance Ranging - No Response received - T3 time-out;
Cabling looks fine, have attached the usual info below, would appreciate any feedback as I don’t seem to be getting anywhere with support.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/4d8fdca7bb54bcf8f9280ce629c6506f5ae1cb8c-04-06-2024
3.0 Downstream channels
1 331000000 2.9 42 QAM 256 25
2 139000000 7.2 43 QAM 256 1
3 147000000 7 43 QAM 256 2
4 155000000 6.7 43 QAM 256 3
5 163000000 6.3 43 QAM 256 4
6 171000000 6.1 43 QAM 256 5
7 179000000 6.1 43 QAM 256 6
8 187000000 5.9 43 QAM 256 7
9 195000000 6 43 QAM 256 8
10 203000000 5.7 43 QAM 256 9
11 211000000 5.6 43 QAM 256 10
12 219000000 5.4 42 QAM 256 11
13 227000000 5.1 42 QAM 256 12
14 235000000 4.8 42 QAM 256 13
15 243000000 4.5 42 QAM 256 14
16 251000000 4.4 42 QAM 256 15
17 259000000 4.4 42 QAM 256 16
18 267000000 4.3 42 QAM 256 17
19 275000000 4.2 42 QAM 256 18
20 283000000 4.1 42 QAM 256 19
21 291000000 4.1 42 QAM 256 20
22 299000000 3.9 42 QAM 256 21
23 307000000 3.8 42 QAM 256 22
24 315000000 3.6 42 QAM 256 23
25 323000000 3.4 42 QAM 256 24
26 339000000 2.9 42 QAM 256 26
27 347000000 2.8 42 QAM 256 27
28 355000000 2.6 42 QAM 256 28
29 363000000 2.4 42 QAM 256 29
30 371000000 2.3 42 QAM 256 30
31 379000000 2.4 42 QAM 256 31
32 387000000 2.4 42 QAM 256 32
1 Locked 42 3 15
2 Locked 43 1 7
3 Locked 43 1 7
4 Locked 43 1 7
5 Locked 43 1 7
6 Locked 43 1 8
7 Locked 43 1 8
8 Locked 43 1 9
9 Locked 43 0 0
10 Locked 43 4 39
11 Locked 43 8 36
12 Locked 42 3 38
13 Locked 42 4 37
14 Locked 42 8 33
15 Locked 42 5 33
16 Locked 42 6 35
17 Locked 42 5 33
18 Locked 42 3 31
19 Locked 42 5 26
20 Locked 42 4 25
21 Locked 42 5 21
22 Locked 42 4 22
23 Locked 42 5 17
24 Locked 42 6 14
25 Locked 42 3 16
26 Locked 42 2 15
27 Locked 42 1 15
28 Locked 42 1 14
29 Locked 42 3 13
30 Locked 42 1 15
31 Locked 42 1 15
32 Locked 42 1 14
3.1 Downstream channels
159 94 4K 1840 QAM 4096 1108
159 Locked 43 1.8 32757745 91
3.0 Upstream channels
0 49600000 47 5120 QAM 64 1
1 43100000 46.5 5120 QAM 64 2
2 36600000 46.5 5120 QAM 64 3
3 30100000 46 5120 QAM 64 4
4 23600000 44.5 5120 QAM 64 5
0 ATDMA 0 0 2 0
1 ATDMA 0 0 0 0
2 ATDMA 0 0 0 0
3 ATDMA 0 0 0 0
4 ATDMA 0 0 0 0
3.1 Upstream channels
6 10 41.0 2K QAM 256
Channel Channel Type Number of Active Subcarriers First Active Subcarrier (Hz) T3 Timeouts
6 OFDMA 200 74000000 0
1 Reply
  • Ashleigh_C's avatar
    Ashleigh_C
    Hi there pwater1
    I am so sorry that you have faced this issue with your connection, is the Hub currently in modem mode? If so can you change this to router mode so we can run full checks.
