TC-BTN's avatar
TC-BTN
Connecting new Haier Washer Dryer to Home WiFi
Can someone please help with a Wifi connection issue as I cannot get my new Haier Washer/Dryer to connect to the app. The manual says it has to connect to 2.4 GHz frequency and I understand my SuperHub 3 uses 2.4 and 5.
Is there a way to connect the washing machine to only 2.4?
The engineer came out and wanted to change the motherboard but Haier has now confirmed that the dual-frequency Virgin router is probably the issue.
I would appreciate any advice.
  • Connect to the Hub 3 admin menu at http://192.168.0.1/   and disable the 5GHz Wi-Fi.
    Now connect your Haier Washer/Dryer & once that is done , re-enable the 5GHz Wi-Fi of the Hub 3.
    IoT : Oh la la !
