Kitty666's avatar
Kitty666
Settling in
7 months ago
Cable for hub 5x, M500 fibre
My cable that connects internal wall box and hub 5x is broken, I’ve been told it is coaxial cable by virgin media customer support. I am wondering if that is correct?
Looked on google, coaxial cable looks different to my current one and coaxial is for older virgin routers.
Does anyone know what cable that hub5x use? I am so worried receiving wrong cable after 3-5 working days of waiting.
    • Kitty666's avatar
      Kitty666
      Settling in
      Don’t know what virgin insists it is coaxial cable for 5x
    It’s a fibre optic cable for the 5X.
    • Kitty666's avatar
      Kitty666
      Settling in
      Thank you, 10M cable is currently on promotion, virgin one is too short
  • Will virgin notice I use my own one ,and then degrade my service?
      As long as there is no dust or dirt ingress as the light transmission can be affected.
  • Roger_Gooner's avatar
    Roger_Gooner
    Why would you pay for cable and install it yourself when VM can do a better job for free.
    • Cardiffman282's avatar
      Cardiffman282
      Community elder
      In this case VM doesn't even know the correct cable type to install in the first place.
