sl1m_tc
8 months agoDialled in
Anyone on Gig1 Fibre still on DOCSIS 3.0 with a Hub 5?
Hey everyone,
I’m on the Volt Gig1 Fibre package and using a Hub 5, which I thought would be running on DOCSIS 3.1 by default. But when I check my modem status, it looks like the downstream is still locked on SC-QAM, which I believe means it’s using DOCSIS 3.0 instead of 3.1.
Just curious — is anyone else on Gig1 seeing the same thing?
Or is your Hub 5 actually bonding to DOCSIS 3.1 (OFDM)?
If you’ve managed to get 3.1 working properly, did you have to contact Virgin to push an update or reprovision your connection? Or did it just switch over automatically for you?
Appreciate any insights. I’m just trying to make sure I’m getting the most out of the package and hardware. 😊
Thanks in advance!
