hackneyuser's avatar
hackneyuser
Advice please. Need to connect existing cable internet connection to new computer
I have searched site and cant find info.
So after many years I am getting a new Windows computer.
Apart from loss of connection last year (eventually sorted) hub and computer connection all working.
But I realise I have no idea how to connect I new computer.
Do I just plug in the cable currently connected to my old computer into my new computer. Or ... ?
If there is a help page about this happy to try and follow but cant find anything on VM website.
  • Roger_Gooner's avatar
    Roger_Gooner
    Unless you've made a change the WiFi SSID and password are on a label on the hub.
    • hackneyuser's avatar
      hackneyuser
      Thanks for that info about password.
      I should have realised as I have used that to link a set top (tv) box to my hub!
    hackneyuser
    Many thanks for your reply.
    I sort of assumed that, and I do have a wired connection.
    Which is just as well as I have no idea what my wi-fi password is!
  • Generally, yes. For wired (Ethernet) devices you can simply unplug the Ethernet cable from your old computer and plug it into your new computer.
    Should work straight away.
    https://commons.wikimedia.org/wiki/File:Ethernet_Connection.jpg
    For your wireless (Wi-Fi) devices you'll need your Wi-Fi password which is usually printed somewhere on your Hub.
