Shenco
6 hours agoJust joined
15m Ethernet Cable
I'm looking to move my router from its current location on the floor and next to TV, to a shelf on other side of room
Therefore, can you please send me a 15 metre ethernet cable ?
If you're moving the router you need a coax cable, not ethernet. VM won't supply a 15m coax, you'll need a technician to fit one and check signal levels.
I suspect the OP is looking for a co-ax cable?
VM will not give you ethernet cables but you can buy them
According to recent posts they'll send them out free of charge ......
